Study event properties
Properties common to all study objects
All study objects have the following properties.
Property
Description
Description
Description of the study object. The description can have 0-255 characters.
Identifier
Unique internal identifier of the study object.
Locked
When True, the study object is locked.
Modified
When True, the study object has not been saved since the last modification.
New
When True, the study object has not been saved yet. When False, the study object has been saved at least one time.
Protected
When true, the study object is protected. When a study object is protected, you cannot:
- Update or lock it.
- Add child study objects to it by pasting or dragging and dropping.
- Delete its child study objects.
RefName
RefName of the study object. The RefName can have 1-63 characters.
Revision
Revision number of the study object.
Title
Title of the study object. The title can have 1-63 characters.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Property
Description
CIS
Block Key Value
Value of the Clintrial block key, used for data transfer to the Clintrial application through CIS mappings. If you specify this value, it overrides the visit RefName as the block key.
InForm
Optional
True or False (default), indicating whether the formset (visit) is optional or required.
Special Visits
When a special visit type is selected, the study event is deployed as a special InForm visit.
Standard properties
Repeating
When True, the study object is repeating.
Short Title
Short title of the study event. The short title deploys to the InForm application as the visit mnemonic. The short title can have 1-63 characters.
