Study Events Editor
Columns common to all study object editors
All study object editors have the following columns.
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Property
Description
Icon (first column)
Status of the study object:
—New. —Locked. —Protected. When a study object is protected, you cannot :- Update or lock it.
- Add child study objects to it by pasting or dragging and dropping.
- Delete its child study objects.
Description
Description of the study object. The description can have 0-255 characters.
Identifier
Unique internal identifier of the study object.
Published (only in libraries)
Indicates that the study object has been published.
RefName
RefName of the study object. The RefName can have 1-63 characters.
Revision
Revision number of the study object. The revision number is incremented each time the study object is changed and saved.
Title
Title of the study object. The title can have 1-63 characters.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Option
Description
Block key value
Value of the Clintrial block key, used for data transfer to the Clintrial application through CIS mappings. If you specify this value, it overrides the visit RefName as the block key.
Optional
Indicates whether the study event is optional or required.
Repeating
Indicates whether the study event is repeating.
Short Title
Short title for the study event.
Special Visits
Indicates whether the study event is an InForm special visit.
