Custom Events editor—Option descriptions
All study object editors have the following columns.
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Columns common to all study object editors
Property |
Description |
Icon (first column) |
Study object's status. |
Description |
Study object's description. |
Identifier |
Unique internal identifier of the study object. |
IPR Status |
Indicates whether the study object has an IPR configuration. |
Published (only in libraries) |
Indicates that the study object has been published. |
RefName |
RefName of the study object. Note: We recommend that you don't use Conflict for a study event RefName, as there is a default Conflict visit created for InForm. |
Title |
Title of the study object. |
Field |
Description |
Active |
The custom event's active status. |
Destination Name |
The destination application where InForm sends the exported data. |
Endpoint Name |
The endpoint name corresponds to the Endpoint Alias in InForm Publisher. |
Evaluate On |
Indicates whether to run the custom event against new data only, or new data and existing data. |
Integration Type |
The integration type that you selected for the custom event. Integration types are added in the Central Designer Administrator. |
Prerequisite |
The name of the custom event that needs to run before the current custom event can be triggered. |
Priority Group |
The order to run the custom events in. |
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
