Export Translations dialog box—Option descriptions
Export Translations dialog box - option descriptions
Option  |
Description  |
Field  |
Locale to translate from  |
Name of the locale in which the text strings to translate have been defined. Note: The Locale to translate from is not the global default locale that is defined in the Tools > Options dialog box, but rather any locale in which the text strings to export exist.  |
Translate <locale name> to  |
Locale into which strings will be translated.  |
Target  |
Target application for which to translate strings.  |
Export file location  |
Location and file name in which to store the file of strings to translate. By default the file name has the format: <StudyName>_ExportTranslations_<TargetSystem>_<SelectedLocale>.csv For example: TestStudy_ExportTranslations_InForm_fr-FR.csv The Browse button enables you to browse to the location.  |
Include empty locale values  |
Export log results  |
Displays messages that are generated during the export. Optionally, you can save these results to a file by clicking the Save Log Results As button.  |
Button  |
Check for Empty Strings  |
Opens a window listing all strings that are empty in the locale to translate from.  |
Save Log Results As  |
Specifies the location of a log file containing the messages that are generated in the Export log results box during the export.  |
