Previous Topic
Next Topic
Book Contents
Rules tab—Option descriptions
Option
Description
Toolbar buttons
New Rule
Edit
Delete
Create, edit, or delete a data-entry rule.
Check Syntax
Check the syntax of a rule.
Cut
Copy
Paste
Cut, copy, or paste a data-entry rule.
Enable
Disable
Enable all disabled rules or disable all enabled rules for a study object.
To enable or disable only parent rules for a study object, deselect the Show Child Rules checkbox before clicking the button.
Show Errors/Hide Errors
View the errors associated with the rule. You must check syntax before you can view errors.
Rule Tests
Open the Rule Test Cases dialog box and create rule test cases.
Top section
When selected, all data-entry rules on the selected study object and its children appear in the grid.
Summary grid
Description
Description of the rule.
Expression
Expression of the rule.
Id
Identification information for the rule.
Lock icon
Appears if the rule is locked.
Parameters
Parameters for the rule template.
Parent
Title of the study object to which the rule is attached.
Parent RefName
RefName of the study object to which the rule is attached.
Parent Type
Type of study object (such as a form) to which the rule is attached.
RefName
RefName of the rule.
Syntax icon
Indicates the validity of the rule syntax.
  • Syntax icon. Rule is valid.—Rule syntax is valid.
  • Syntax icon. Rule has one or more warnings.—Rule syntax has one or more warnings associated with it, or the rule could not be compiled.
  • Syntax icon. Rule is invalid.—Rule syntax contains one or more errors and is not valid.
Target
Target application to which the rule is deployed.
When
Event that triggers the rule (you select this option from the Evaluate on Event drop-down list in the Rule Wizard).
Rule Summary section
A structured specification of the rule appears, with links that open the Rule Wizard.
Send Feedback
