Workflow Expression Editor dialog box—Option descriptions
Use the Workflow Expression Editor dialog box to create the expression for a workflow rule in a Workflow Diagram tab.
Option |
Description |
Rule Name |
Name of the workflow rule. |
Rule Description |
Description of the workflow rule. This field is not deployed. Maximum characters: 2000. |
Expression section |
Used for developing the expression for the rule by typing or by dragging in components displayed in the tabs of the References section. When you drag in a component, the reference to the component is converted to the standard Central Designer expression syntax. Typically an expression might contain a combination of typed values (such as operators) and dragged-in components (such as functions or references to study objects). |
Reference tabs—Available components |
List of the components that are available for use in the rule being defined. By default, these tabs appear on the right side of the dialog box. When you select a tab, the Reference section appears, with tabs along the bottom edge. |
Data tab |
The available study objects appear in a tree structure similar to the Project Explorer. |
Functions tab |
The available functions appear in a tree structure organized by class. Note: Functions are defined in the Study Editor or Library Editor. |
Constants tab |
The available constants appear in a tree structure organized by class. Note: Constants are defined in the Study Editor or Library Editor. |
Data Mappings tab |
The components of the available mappings appear in a tree structure similar to the Project Explorer. |
Show All checkbox |
When selected, all available study objects as well as their properties appear. When not selected, only the available study objects appear. |
