Design tab of the Codelist Editor—Option descriptions
Option |
Description |
Title (codelist) |
Title of the codelist. The title can have 1-63 characters. |
Description |
Description of the codelist. |
Data type |
Data type of the codelist; must be compatible with the values specified for codelist item codes:
Pulldown display order |
Determines how the codelist will be displayed to the end user. The available options are:
Fields |
Title (codelist item) |
Title of the codelist item. The title can have 1-63 characters. |
Code |
Value stored in the repository for the codelist item. The value can have 1-2000 characters. |
Label |
Default label that appears on the form for the codelist item. The label can have 1-255 characters. |
Description |
Description of the codelist item. The description can have 0-255 characters. |
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
