Previous Topic
Next Topic
Book Contents
Deployment Setup tab—Option descriptions
Study Setup—Option descriptions
Option
Description
Buttons
Test URL
Test the URL of the selected deployment instance.
If the test fails, automated deployment fails. The test is successful when:
  • The URL and port are valid for the InForm web service that is associated with the deployment instance.
  • The Central Designer deployment certificate is installed on the InForm server.
  • The Central Designer application can connect with the InForm web service.
  • The type of the deployment instance matches the type selected for the InForm web service.
  • The Approval Required setting for the deployment instance matches the setting for the InForm web service.
  • The rule engine that is installed on the Central Designer server is also installed on the InForm server.
For more information, see the InForm Installation Guide.
Audit History
Display all the revisions of the selected deployment instance study object.
Columns
Select the columns to display.
Lock and Protect
Lock or protect the selected study object.
Columns
Icon (first column)
Status of the study object:
  • Icon_New—New.
  • Icon_Locked—Locked.
  • Icon_Protected—Protected. When a study object is protected, you cannot :
    • Update or lock it.
    • Add child study objects to it by pasting or dragging and dropping.
  • Delete its child study objects.
Description
Description of the deployment instance.
Type
Type of deployment instance:
  • UAT—User acceptance testing
  • QA—Quality assurance
  • DEV—Development
  • LIVE—Production
  • TRN—Training
URL
URL address of the deployment instance.
Port
Port number of the web service used to query deployment status.
Approval Required
Indicates whether deployments to the server must be approved by a user with the appropriate right, as configured in the Central Designer Administrator application.
Send Feedback
