Previous Topic
Next Topic
Book Contents
In-Place Revision Summary Editor—Option descriptions
IPR Summary Editor—Option descriptions
Option
Description
Buttons
Edit
Edit the IPR configuration for the selected in-place revision.
Delete
Delete the selected in-place revision.
IPR Configurations
Copy IPR configurations from one deployment instance to another, or remove IPR configurations from selected deployment instances.
Select All
Select all in-place revisions.
Lock and Protect
Lock or protect the selected in-place revision objects.
History
Open the IPR History dialog box to view a history of in-place revisions for all baselines with in-place revisions that were successfully deployed to LIVE deployment instances.
Note: The IPR History dialog box only contains information about IPRs applied through automated deployments.
Columns
RefName
RefName of the in-place revision study object.
Type
Type of revised study object.
Deployment Instance
Deployment instance to which to deploy the in-place revision.
Description
Description of the change.
Send Feedback
