Form and section properties
Properties common to all study objects
All study objects have the following properties.
Property
Description
Description
Description of the study object. The description can have 0-255 characters.
Identifier
Unique internal identifier of the study object.
Locked
When True, the study object is locked.
Modified
When True, the study object has not been saved since the last modification.
New
When True, the study object has not been saved yet. When False, the study object has been saved at least one time.
Protected
When true, the study object is protected. When a study object is protected, you cannot:
- Update or lock it.
- Add child study objects to it by pasting or dragging and dropping.
- Delete its child study objects.
RefName
RefName of the study object. The RefName can have 1-63 characters.
Revision
Revision number of the study object.
Title
Title of the study object. The title can have 1-63 characters.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Form properties
Property
Description
CIS properties
Page Key Value
Value of the Clintrial page key, used for transferring data to the Clintrial application through CIS mappings. If you specify the Page Key Value, it overrides the form RefName as the page key.
InForm properties
Item Required
True (default) or False, indicating whether the item is required.
SDV Required
True (default) or False, indicating whether the item requires source document verification.
SDV Critical
True or False (default), indicating whether the item is considered critical for source verification. If you select True, SDV Required changes to True.
Special Forms
Type of special InForm field, or None, indicating that the item is not a special InForm field. Available special fields, along with the forms in which they appear, are:
- Initials (Screening).
- DOB (Screening).
- Screening date (Screening).
- Patient No. (Enrollment).
- Initials (Patient Identification.
- Completion status (Study Completion).
- Drop-out reason (Study Completion).
- DOV (Date of Visit).
- Randomization field (Randomization).
Standard properties
AssociatedForm
Indicates whether the form is an associated form.
- None—Form is not an associated form.
- [Form name]—Name of the form with which the form is associated.
Common
When True, the form is a common form.
Tip: Do not change this setting for a form that was already deployed. Instead, to avoid potential negative downstream impact, create a new form with the updated setting.
Fixed
For sections only. When True (used for repeating sections), the section contains items that are deployed as a Repeating Data itemset.
Repeating
When True, the study object is repeating.
Short Title
Short title of the form, used as a mnemonic when deployed.
