How are units of measurement mapped?
When an integer or float item that has data collected in multiple units is added to a data series in a mapping, the Item has units dialog box appears, prompting you to choose the data value to map to the data series. You have the following options.
Options for adding data to a data series in a mapping
Option |
Description |
Normalized Value |
Map the normalized value of the item with the data series. Normalization is the process of converting data to a required format. The normalized units appear in parentheses. |
Entered Value |
Map the entered value of the item with the data series. The entered value can be the same as or different from the normalized value. |
Entered Unit |
Map the unit in which a value is entered. |
For example, a Weight item appears on three forms. Two forms collect the weight value in kilograms, and one form collects the weight value in pounds. The Weight items are normalized to kilograms. You can map different types of values to different data series, as shown in the following example.
Example of options for adding an item to a data series
Values collected or mapped |
Source |
Values in data series |
Values collected for the Weight items |
Form 1 Form 2 Form 3 |
75 kg 155 lb 62 kg |
Normalized values mapped to a data series |
75 70.45 62 |
Entered values mapped to a data series |
75 155 62 |
Entered units mapped to a data series |
kg lb kg |
