Subject_Lab Test data set
in the Subject_LabTest data set
Data Series Title |
Description |
Location in Argus Safety |
Test_DateTime |
Date and time of the lab test or procedure. |
Case Form / Patient / Lab Data / Lab Data / Date |
Test_Name |
Name of the lab test or procedure performed to diagnose or confirm the adverse event or to investigate a non-drug cause. Note: If the mapped item is a codelist item, the label for the codelist will be sent instead of the value. If the item is not a codelist item, the value stored for the item will be sent. |
Case Form / Patient / Lab Data / Lab Data / Test |
Test_Result |
Result of the lab test or procedure. |
Case Form / Patient / Lab Data / Lab Data / Results |
Test_UOMCode |
Unit of measure for the result of the lab test or procedure. |
Case Form / Patient / Lab Data / Lab Data / Units |
Test_NormalLowRange |
Normal low range for the lab test or procedure. |
Case Form / Patient / Lab Data / Lab Data / Norm Low |
Test_NormalHighRange |
Normal high range for the lab test or procedure. |
Case Form / Patient / Lab Data / Lab Data / Norm High |
Test_AdditionalInformation AvailabilityIndicator |
Whether additional information is available for the lab test or procedure. |
Case Form / Patient / Lab Data / Lab Data / Notes |
