Previous Topic
Next Topic
Book Contents
About publishing, republishing, and unpublishing
You must publish study objects that were created in a library to allow users to search for them in the Libraries Browser. You can publish, republish, and unpublish study objects only in a library. You must save a study object before you publish or republish it.
In a library, you can publish any of the following.
Study objects that you can publish
What to publish
Notes
A single study object.
When you publish a study object, you publish its most recent version or revision.
A study object and its child study objects.
  • When you publish a form and its children, sections on the form are also published.
  • Publishing child study objects is not supported for mappings.
  • If you modify a study object or one of its children, you can use the Republish option to publish the study object and its children again.
  • If you copy a study object with child study objects from the Libraries tab to a study or library, the child study objects are also copied, regardless of whether or not they are published.
All study objects.
Tip Tip: To prevent users from finding study objects using the Libraries tab, unpublish the study objects.
Send Feedback
