Previous Topic
Next Topic
Book Contents
What information can I define for templates and types?
The following table contains examples of the kinds of information that you can define for templates and type. All study objects created from a template or type inherit the characteristics of the template or type.
Note: You can create a study object, such as a study or study event, copy study objects to it from a library, and then mark the study object as a template. If you use the template to create a study object, the study objects that were copied from the library do not retain history information from the study objects in the library.
Information you can define for templates and types
Study object
Templates
Study project
  • The references required for creating studies in the project, such as protocols or goals.
  • Any studies or study objects that are contained in the project.
Study
  • Study deployment requirements, including languages and form layouts.
  • Study language requirements.
  • A defined Library List containing the libraries from which study objects and templates will be taken to build the study.
  • The references required for building a study, such as a protocol or study goals.
  • The users (assigned to study teams) who will be working on the study.
  • The instructions and Help information for the study.
  • The functions and constants that will be used in the study.
  • Workflow components, including commonly used forms, special forms, and any other commonly used study objects.
  • Mappings, including items and mappings to items, forms, and study events.
Study element
  • The study objects contained in the study element and their workflow.
  • Instructions and Help for the study element.
Study event
  • The study objects contained in the study event and their workflow.
  • Instructions and Help for the study event.
Form
  • A designed layout.
  • The study objects contained in the form.
  • Instructions and Help for the form.
Item
  • Design information, including a question, title, units, and length.
  • A codelist including codes and labels.
  • Data entry rules, such as a range check.
  • Instructions and Help for the item.
Codelist
  • The codes and labels contained in the codelist.
Mapping
  • A name, RefName, and description of the mapping.
  • The data sets, data series, and items contained by the mapping.
Types
Item
Send Feedback
