Map the data series to a specific instance of an item
Most data sets are associated with elements in the safety event transmission that occur only once. You map the data series in these data sets to a specific instance of an item:
- In a non-repeating section (that is, not an InForm itemset).
- On a non-repeating form.
- In a non-repeating visit.
- On the instance of the AE form that is being submitted. Although the AE form is most often repeating, only the data in the current instance of the AE form being submitted is transmitted.
If the item is on a form that occurs in multiple visits, you must map the data series to a specific instance of the study event and form.
Note: You can map multiple items to the same data series, and you can map similar items from different forms to the same data series in a repeating data set. For example, you can map items from a Lab Local and a Lab Central form to the same data series in the Subject_LabTest data set. When you do this, the safety event transmission treats the items as coming from different instances, so the transmission message contains a different element for each form. To do this, make a copy of the entire dataset or add them into the current one. Then map one dataset to the LabLocal form and the other to the LabCentral form.
