Test the deployment instance
To test the deployment instance URL:
- At the bottom of the Project Explorer, click the Study Information (
) button. - Select a study.
- Select the Deployment Setup tab.
- Select the URL.
- On the toolbar at the top of the Deployment Setup tab, click the Test URL button.
Note: When using Federation credentials, it is recommended to also validate the compatibility of your Federation Identity Provider (IdP) by attempting a non-LIVE autodeployment, since a non-compatible IdP may cause the deployment to fail. If this is the case, please log in using your IAMS credentials instead.
For more information on Federation credentials, see the InForm User Guide for Site Users.
