Create rules for the narrative
In the NarrativeUpdatesOnly system setting, define how the Safety Case form will group new narrative items when sending them to Argus.
NarrativeUpdatesOnly = No
lab
Item |
Description |
When to use |
If you are selecting No for NarrativeUpdatesOnly to send the cumulative narrative for each transmission to Argus. |
Purpose |
To add submited text from the editable text field into a ReadOnly field cumulatively and clear the editable text field. |
Triggering controls |
Form submission. |
Action when rule is triggered |
Copies narrative text entered by site to ReadOnly fields. |
Rule expression |
The rule below is an example of a rule that could be written on the Safety Case form. In this case, there are 3 editable narrative fields named D_NARRATIVE1_001, D_NARRATIVE1A_001 and D_NARRATIVE1B_001 that are to be mapped to the 5 ReadOnly fields D_NARRATIVE2_001, D_NARRATIVE3_001, D_NARRATIVE4_001, D_NARRATIVE5_001, and D_NARRATIVE8_001, depending on the length of the entered string and space left in each mapped field. When the length of the entered text (combined) exceeds the combined max length of the 5 mapped fields, the mapped text in the first text box will be overwritten by the remaining text. Once the text is mapped over to the target fields, the editable field clears out. You have the ability to update the editable narrative fields until the Send to Safety checkbox is checked.
evaluate on Form Submission value = (!this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.Empty || !this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.Empty || !this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.Empty) && !this.D_ESAE001.Current().D_ESAE23001.D_SAESUBMIT_001.Empty ? ( this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE2_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE3_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE4_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE5_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE8_001.GetValue("") + Environment.NewLine + Environment.NewLine + "##" + Functions.GetSiteTime().ToString("ddMMMyyyyHHmm") + "##" + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.GetValue("")).Length > 10000 ? ( this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE2_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE3_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE4_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE5_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE8_001.GetValue("") + Environment.NewLine + Environment.NewLine + "##" + Functions.GetSiteTime().ToString("ddMMMyyyyHHmm") + "##" + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.GetValue("")).Substring( ( this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE2_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE3_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE4_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE5_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE8_001.GetValue("") + Environment.NewLine + Environment.NewLine + "##" + Functions.GetSiteTime().ToString("ddMMMyyyyHHmm") + "##" + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.GetValue("")).Length - 10000,10000) : ( this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE2_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE3_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE4_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE5_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE8_001.GetValue("") + Environment.NewLine + Environment.NewLine + "##" + Functions.GetSiteTime().ToString("ddMMMyyyyHHmm") + "##" + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.GetValue("") + this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.GetValue("")) :"99" when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE5_001.Value = value.Length >= 6000 ? value.Length >= 8000 ? value.Substring(6000,2000): value.Substring(6000,value.Length-6000) : " " when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE4_001.Value = value.Length >= 4000 ? value.Length >= 6000 ? value.Substring(4000,2000): value.Substring(4000,value.Length-4000) : " " when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE3_001.Value = value.Length >= 2000 ? value.Length >= 4000 ? value.Substring(2000,2000): value.Substring(2000,value.Length-2000) : " " when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE2_001.Value = value.Length >= 2000 ? value.Substring(0,2000): value.Substring(0,value.Length) when value != "99" set this.D_ESAE001.Current().D_ESAE22001.xNARRATIVE1N.Value = this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.Value when value != "99" set this.D_ESAE001.Current().D_ESAE22001.xNARRATIVE1AN.Value = this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.Value when value != "99" set this.D_ESAE001.Current().D_ESAE22001.xNARRATIVE1BN.Value = this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.Value when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1_001.Value = " " when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1A_001.Value = " " when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE1B_001.Value = " " when value != "99" set this.D_ESAE001.Current().D_ESAE22001.D_NARRATIVE8_001.Value = value.Length >= 8000 ? value.Length >= 10000 ? value.Substring(8000,2000): value.Substring(8000,value.Length-8000) : " " |
NarrativeUpdatesOnly = Yes
lab
Item |
Description |
When to use |
If you are selecting Yes for NarrativeUpdatesOnly to send the incremental narrative for each submission to Argus. |
Purpose |
To add submited text from the editable text field into a ReadOnly field cumulatively, overwrite its corresponding Hidden field, and clear the editable text field. |
Form submission. |
Copies narrative text entered by site to Hidden and ReadOnly fields. |
Rule expression |
The rule below is an example of a rule that could be written on the Safety Case form. In this case, there are 3 editable narrative fields named D_NARRATIVE1_001, D_NARRATIVE1A_001 and D_NARRATIVE1B_001 that are to be mapped to the 5 ReadOnly fields D_NARRATIVE2_001, D_NARRATIVE3_001, D_NARRATIVE4_001, D_NARRATIVE5_001, and D_NARRATIVE8_001, depending on the length of the entered string and space left in each mapped field. When the length of the entered text (combined) exceeds the combined max length of the 5 mapped fields, the mapped text in the first text box will be overwritten by the remaining text. Once the text is mapped over to the target fields, the editable field clears out. Also in this example, all narrative editable text fields are mapped to the same number of Hidden fields on a 1 to 1 basis. You have the ability to update the editable narrative fields until the Send to Safety checkbox is checked.
xRuleNarrative1Ato1D evaluate on Form Submission value = !this.D_NARRATIVE1A_001.Empty ? 2 : 101 when value == 2 set this.D_NARRATIVE1D_001.Value = this.D_NARRATIVE1A_001.Value when value == 2 set this.D_NARRATIVE1A_001.Empty = true when value == 101 set this.D_NARRATIVE1D_001.Value = " "
xRuleNarative1to1C evaluate on Form Submission value = !this.D_NARRATIVE1_001.Empty ? 1 : 100 when value == 1 set this.D_NARRATIVE1C_001.Value = this.D_NARRATIVE1_001.Value when value == 1 set this.D_NARRATIVE1_001.Empty = true when value == 100 set this.D_NARRATIVE1C_001.Value = " "
xRuleNarrative1Bto1E evaluate on Form Submission value = !this.D_NARRATIVE1B_001.Empty ? 3 : 102 when value == 3 set this.D_NARRATIVE1E_001.Value = this.D_NARRATIVE1B_001.Value when value == 3 set this.D_NARRATIVE1B_001.Empty = true when value == 102 set this.D_NARRATIVE1E_001.Value = " " |
