Designing with the Central Designer software
The following steps illustrate a typical integrated design scenario in which the Central Designer software is the primary design tool.
- Using the Central Designer software, develop a study.
- Using the Central Designer software, create a deployment package for the study.
- Deploy the package to the InForm study database. The deployment process installs the MedML metadata definitions and the CIS mapping definitions in the InForm study database.
- Using CIS Administration, create a synchronization connection between the InForm study database and the Clintrial clinical database, and transfer the protocol component definitions to the Clintrial database through the synchronization process.
- Using the Clintrial Design module, refine the protocol component definitions as needed to accommodate paper-based data entry.
For more information, see:
- Working with data mappings in the CIS Designer Guide.
- Central Designer documentation.
