InForm and Clintrial data incompatibility
CIS generates mapping definitions for study components. if you generate mappings in the Central Designer software and synchronize the metadata definitions to the Clintrial software, the CIS software optionally creates Clintrial panels, if they do not already exist, and the metadata definitions match between the InForm study and the Clintrial protocol.
However, if you later add to or change the study component or protocol item definitions, you can create data incompatibilities if you do not ensure that the additions or changes are correctly reflected in both systems. This section describes common data incompatibility problems.
