Editing a user profile
You can change basic user information including the user password.
- Select Settings > Security.
The Security Administration page appears with the Users tab selected.
- Click the link for the user you want to view.
The Edit User page appears with the Profile tab selected. From this tab, you can make changes to general information about the user.
- To change the user password, select Change Password.
The Password and Confirm password fields are enabled.
Important: If you change the password for the Service user, you must also change this password in the Settings tab of the CIS Synchronization Adapter page. For more information, see Viewing and changing global synchronization connection settings.
- In the Password field, type a new password.
Note: When you create a password, you must follow the rules and requirements defined in the Configuration Settings page. For more information, see Viewing and changing security settings.
- In the Confirm Password field, retype the password.
- Click Save.
