Identifying the Clintrial database instance
- If the Clintrial Machine field has a drop-down list, select the computer where the Clintrial instance for the synchronization connection is installed.
- If the Clintrial Machine field has a drop-down list, in the Clintrial Instance group, click Register new.
- Complete the fields on the page, and click Next.
The CIS Synchronization Connection Wizard - Clintrial Protocol page appears.
CIS Synchronization Connection Wizard - Clintrial Instance page - Fields.
Field
Description
Instance
Name of the Clintrial database instance.
CISUSER password
Password for the CISUSER user in the database instance.
Get State Options
Click to populate the State to map queries as open list box.
Clintrial discrepancy status that corresponds to the InForm Open query status. There is no default; you must specify a value. This information is used for transfer of query (discrepancy) information from the Clintrial database back to the InForm database.
If the value you specify for "State to map queries as open" matches the value in the Clintrial software for "Discrepancy initial status" for the Clintrial rule, the Clintrial discrepancy maps as an Open query in the InForm software. If the values do not match, the Clintrial discrepancy maps as a Candidate query in the InForm software.
Note: If in the Clintrial software the value for "Discrepancy initial status" of a Clintrial rule is not specified, the CIS software assumes the default value "Ready to Send".
