Overview of registering an InForm Adapter
After installing the InForm Adapter, you must:
- Make sure that the InForm Adapter security configuration reflects the level of security you intend to use in CIS:
- On the InForm Adapter server, import the Digital Certificate that you set up in CIS into the Personal Store.
For more information, see the InForm Adapter Installation Guide.
Note: Consider the hierarchy of the certificate. For example, if you create a certificate for CIS called cis463, and the certificate is a child of US-SLC03FJP-CA, both must be imported to the appropriate certificate stores on the InForm Adapter servers.
- Register the InForm Adapter for use in the CIS environment. You register an InForm Adapter by providing the URL for the adapter. Use the Find Adapter page of the Register Adapters Wizard.
Note: If you use a hardware load-balancing machine to distribute transaction processing to different InForm Adapters, you must import its certificate to the Personal Store on each CIS server. To register the load-balancing machine, you enter the URL for that machine.
From the Find Adapter page of the Register Adapters Wizard, you can register an InForm Adapter.
