Overview of removing a synchronization connection
If you make an error defining a synchronization connection, or if you no longer need a synchronization connection, you can remove the synchronization connection definition.
Note: Removing a synchronization connection does not remove the InForm trial or the Clintrial protocol.
To remove a synchronization connection, you use the Actions tab of the CIS Synchronization Adapter page.
