Overview of starting or stopping a synchronization manually
You can use the following options to start or stop a synchronization.
- Sync Now allows you to start a synchronization manually. This option is usually used when there is no schedule defined for the synchronization connection. For more information, see:
You start a synchronization manually from the Sync Connections tab of the CIS Synchronization Adapter page.
- Stop Sync allows you to stop a synchronization manually. For more information, see Stopping a synchronization manually.
