Overview of configuration settings
You use the Configuration page to view and manage CIS Administration configuration settings.
The Configuration page enables you to:
- Specify settings that apply globally to all components of the CIS environment.
- Set parameters that determine how CIS Administration handles user authentication.
For more information, see:
- General tab of the Configuration page - Fields.
Field
Description
Adapter checking frequency (hours)
Frequency in hours for CIS Administration to check all adapters in the CIS environment to determine whether any of the adapters have changed.
Database checking frequency (minutes)
Frequency in minutes for CIS Administration to check the database for the presence of any new components that need to be placed on the local web server.
System home page
- (Page name)—Name of the initial CIS Administration page that appears when a user logs on. A specific page here overrides any custom home page set by a user if Allow users to set custom page is No.
- None—The system default page (My CIS) appears.
- Yes—Users can specify the page that appears when they log on.
- No—The home page specified in the System home page field appears when a user logs on.
- Security tab of the Configuration page - Fields.
Field
Description
Inactivity timeout (minutes)
Number of minutes a CIS Administration session can be inactive before it times out and CIS Administration logs a user off.
Authentication expiration (hours)
Number of hours after which a user authentication is no longer valid and the user must log on again.
Password expiration (days)
Number of days before a user password expires and the user must change the password when logging on.
Minimum password length
Minimum number of characters a user password must contain.
Note: Allowed characters in passwords are upper and lowercase letters, digits, underscore (_), pound sign (#), and dollar sign ($).
Failed logon limit
Number of failed logon attempts a user can make before CIS Administration deactivates a user.
Audit verbosity level
- Any—Save all logon errors.
- Failures only—Save errors only when a logon fails.
- Inactive failures only—Save errors when the inactive period exceeds the value in the Security tab of the Configuration page.
From the Configuration page, you can:
