Taking a load-balancing machine off line
- Select Admin > CIS Sync.
- Select Load Balancing.
The Load Balancing tab appears and displays status information about the machines being used for load balancing.
- In the Load Balancing Machines table, click Edit next to the load-balance machine whose status you want to change.
The Status and Offline Reason fields are enabled.
- In the Status column for the machine you want to change, select Offline from the drop-down list.
- Optionally, in the Offline Reason column, type a reason for taking the machine off line.
- Click Update.
CIS places the load-balanced machine off line. Synchronization transactions bypass the offline machine and are processed on the next available load-balanced machine.
