Columns
The INF_SUBJECT_AUDIT table has the same columns as the INF_SUBJECT table.
Note: The ENTRY_DATETIME column, which could be NULL in the INF_SUBJECT table for records that existed in previous versions of the CIS software, cannot be NULL in the INF_SUBJECT_AUDIT table. If INF_SUBJECT.ENTRY_DATETIME is NULL, then the CIS software creates a value for the new row in INF_SUBJECT_AUDIT.ENTRY_DATETIME that is one second less than the ENTRY_DATETIME of the updated row in INF_SUBJECT.
