System date times
The CIS software components store system dates and timestamps as follows:
Software component |
Storage of system dates and timestamps |
InForm software |
Stored as Universal Time (also called Greenwich Mean Time) (UTC or GMT) and displayed according to the time zone of the user site. |
CIS software |
Stored as UTC/GMT. |
Clintrial software |
Stored as local time on the Oracle machine. In Clintrial audit tables, the ENTRY_DATETIME column reflects the time the record was updated in InForm software (in UTC/GMT), and the MERGE_DATETIME column reflects the time the value was updated in the Clintrial software (in the local time of the Clintrial machine). |
Because the InForm and CIS machines store the same system dates and timestamps, there is no need for the machines to be set to the same time zone as long as their system clocks are synchronized. You should set the Clintrial machine to the time zone you want to use for analyzing data; UTC/GMT is suggested to minimize confusion.
