CIS_SYNCH_JOBS_QUEUE columns
Column name |
Data type |
Description |
JOBQUEUEGUID |
VARCHAR2(36) not null |
Unique identifier for synchronization job. |
JOBQUEUESTATUS |
VARCHAR2(50)null |
String representing the current status of the job. Possible values are:
JOBQUEUESTARTTIME |
DATE null |
Start Time for synchronization job. |
JOBQUEUELASTUPDATE |
null |
Time of last heartbeat as entered by the Synchronization Monitor (SM) thread. |
JOBQUEUEENDTIME |
DATE null |
End time for synchronization job. |
SYNCHGUID |
VARCHAR2(36) null |
Foreign key to synchronization connection table (CIS_SYNCHCONNECTIONS) establishing the synch connection to which a particular job is related. |
SYNCHVERSION |
INTEGER null |
Foreign key to Synch Connection table (CIS_SYNCHCONNECTIONS) establishing the version of the synch connection to which a particular job is related. |
MACHINEGUID |
VARCHAR2(50) null |
Foreign key to load-balance machine table (CIS_LB_MACHINES) establishing the processor handling a connection. |
MACHINEVERSION |
INTEGER null |
Foreign key to load-balance machine table (CIS_LB_MACHINES) establishing version of the processor handling a connection. |
CURRENTACTION |
VARCHAR2(50) null |
String further describing the current activity on an active synchronization. Possible values are:
CLINTRIALPROCESSED |
INT null |
Number indicating the cumulative number of transactions that have been processed by the Clintrial software for this job. |
INFORMPROCESSED |
INT null |
Number indicating the cumulative number of transactions that have been processed by the InForm software for this job. |
