Study design and deployment
In a CIS environment, you can design a study using the Central Designer software.
As a result, you can:
- Reuse components in existing studies that were created using the Central Designer software, that are currently deployed with the InForm software.
- Deploy a completed study definition as:
- A paper-based protocol in the Clintrial software.
- An EDC study in the InForm software.
- A study with both paper-based and EDC sites.
