Previous Topic
Next Topic
Book Contents
Designing with the Central Designer software
The following steps illustrate a typical integrated design scenario in which the Central Designer software is the primary design tool.
  1. Using the Central Designer software, develop a study.
  2. Using the Central Designer software, create a deployment package for the study.
  3. Deploy the package to the InForm study database.
    The deployment process installs the MedML metadata definitions and the CIS mapping definitions in the InForm study database.
  4. Using CIS Administration, create a synchronization connection between the InForm study database and the Clintrial clinical database, and transfer the protocol component definitions to the Clintrial database through the synchronization process.
  5. Using the Clintrial Design module, refine the protocol component definitions as needed to accommodate paper-based data entry.
For more information, see:
Send Feedback
