Reviewing user scenarios
You might want to develop an integrated study if:
- You plan to run an EDC-based study with the InForm software, but you want to take advantage of the coding and data analysis capabilities of the Clintrial software.
- You want to use the visual study design capabilities of the Central Designer software to develop your study, and you want to use the Clintrial database as your study data repository.
- You are running a paper-based study with the Clintrial software, and you want to add EDC-based sites.
This section discusses the issues you should take into consideration when planning an integrated study. For additional information on planning a study, see the following documentation:
- InForm studies—Central Designer User Guide.
- Clintrial studies—Clintrial Admin and Design.
