Comparison of Central Designer, Clintrial, and InForm rules
Characteristic |
Central Designer data-entry rules |
Clintrial rules and derivations |
Written in |
Central Designer rule expression language, using the Rule Wizard. |
PL/SQL. |
Can make calls to |
Predefined functions that are included in the Central Designer rule model, or user-defined functions. Central Designer rules can access numerous rule model properties and methods and can include predefined or user-defined constants. |
Functions and procedures in PL/SQL packages that are provided with the software or created by the user. These functions include:
Associated with |
Study designs, study elements, study events, forms, and items. A data-entry rule can reference:
If the data-entry rule is designed to generate a query or calculate a value, when a study is deployed to the InForm software, the deployment process creates the InForm structures that determine the item or items to be updated. |
A panel within a protocol. Rules and derivations become part of the validation procedure of the panel. If a Clintrial rule fires and fails on EDC data, a query synchronizes back to the InForm software and attaches to an item in the InForm study. The CIS software determines the InForm item on which to place the query by using Clintrial Resolve error items. These items are ordered, and the CIS software evaluates each one in turn, placing the query on the first item that is mapped to a non-calculated InForm item. |
Can be used to validate |
EDC data only. |
EDC or paper-based data, or both. Note: To use Clintrial rules and derivations in an integrated study, you must install the Clintrial Resolve module. |
For more information, see:
- Central Designer data-entry rules—Central Designer guide Working with Rules and Logical Schemas.
- Clintrial rules and derivations—Clintrial Reference Guide.
