Making panel property changes
After a panel is installed in the Clintrial software, you can change the following properties by marking the panel for revision in the Design module:
- SAS Name
- Validation Priority
- Verify
- Protected
- Description
To change the panel definition, use the Central Designer software to make changes to the panel mapping properties, create a new deployment package, and deploy it to the InForm software.
Running a CIS synchronization updates the Clintrial software.
