Integrated study development methodology summary
You can design an integrated study by using the Central Designer software, the Clintrial Design module, or a combination of the two. Consider the following study development guidelines:
- Design the user interface in the environment in which you have the most expertise or in which there are existing components to leverage first.
- Make sure you understand the conversion issues surrounding each type of study component. For information, see the following resources:
- Working with integrated metadata.
- Clintrial Admin and Design.
The following sections summarize study development steps for integrated studies developed by using the Central Designer software and by using the Clintrial software. For information about the decisions and actions required at each step, see the referenced documentation.
