Autogenerated codelists and the Code List property
In the Central Designer software, when you specify CIS mapping properties, you can specify the name of an existing Clintrial codelist as the target for the data in the item that is being mapped.
When CIS synchronization processes mapping definitions and autogenerates codelists, it does not autogenerate codelists for items that have a value in the Code List property, as the Code List property is intended to refer to an existing codelist. Therefore, if you want CIS to autogenerate a codelist for an item, leave the Code List property blank.
