Required item attribute
By default, an item created in an integrated Clintrial protocol does not have its required attribute enabled, even if the corresponding InForm item from which it is mapped is required.
To make a Clintrial protocol item required, you must use the Design module to manually set the required attribute.
Other item attributes may also need to be edited.
