Solution types
In the Propose Solution menu in the Omission Browser for problems in the Needs Proposal state, the Change Verbatim solution type is not available for coding problems related to EDC data. Only the Reuse Solution, Create Synonym, and Request More Info solution types are available.
For the Solution Pending, Applied, or Solved state, only omission records with a Synonym Solution are displayed in the Omission Browser.
