Review and Adjust Monitored Data on the Monitoring Tab
On the Monitoring tab you can specify information about the global and by location monitoring assumptions in a plan.
Your edit mode determines the fields shown on the Monitoring tab. For more information about any field, click the field name to display online help.
- Specify the Monitoring Methods
 Specify whether monitoring will be performed on-site, remotely, centrally, or by a combination of these methods and whether to specify monitoring assumptions globally or by location.
- Accept or Modify the On-site Monitoring Schedule
 The default on-site monitoring schedule uses a frequency-based model to calculate the total number of on-site visits. The frequency impacts the length or duration of the visits.
- Review the Remote Monitoring Schedule
 If you chose Remote from the Monitoring Methods section of the Monitoring tab, the default schedule uses a frequency-based model to calculate the total number of remote visits.
- Review the Remote Monitoring Schedule for Centralized Monitoring
 If you chose Centralized from the Monitoring Methods section of the Monitoring tab, then corresponding default labor will be included in the budget.
- Define the Monitoring Approach
 In the Monitoring Approach section of the Monitoring tab, enter detailed assumptions about who will perform monitoring and how they will work.
- Specify Total CRF Pages Expected
 In the Monitored Data section of the Monitoring tab, enter the total number of CRF pages to be generated and monitored.
- Review and Adjust Medical Monitoring Assumptions
 In the Medical Monitoring section of the Monitoring tab, review and adjust the time for a medical monitor to serve as the team medical lead and provide support to the CRA monitoring staff and investigators for issues beyond safety reporting.
- Review and Adjust Separate Drug Accountability Visits
 Will there be additional drug accountability visits? Separate drug accountability generally applies to oncology and some vaccine studies and is done by someone other than the CRA that monitors the site.
Parent topic: Add Your Assumptions
Parent topic: Review and Adjust Monitored Data on the Monitoring Tab
If you chose on-site from the Monitoring Methods section of the Monitoring tab, you can specify details about the on-site monitoring schedule.
- In the On-Site Monitoring Schedule section of the Monitoring tab, in the Monitor every field, specify how frequently a monitor (CRA) will visit the sites in the study during each period of the monitoring schedule across screening, treatment, and follow-up sements (between FSFV and LSLV).
- Choose the frequency:
                           - If visits will continue at the
              specified frequency throughout the study enrollment, treatment, and follow-up segments
              (FSFV to LSLV or Last Subject Last Follow-up Visit, select until
                LSLV.
                                 When there are no treatment arms with a follow-up treatment defined, then LSLV = LSLT. When there is a follow-up period defined for one or more treatment arms, thenLSLV = LSLFU(Last Subject Last Follow Up visit/data collection event).
- If the monitoring frequency will change during the treatment or follow-up period, select the until week radio button and define a new frequency for the next or remaining intervals.
- If you want to use a variable
              monitoring frequency; for example, visiting every four weeks in the beginning of the
              study, every two weeks in the middle of the study, and every six weeks at the end of
              the study:
                                 - In the Monitor every field, enter the frequency for the first period.
- Select the until week radio button and enter the week at which this frequency ends and a new monitoring frequency begins. This is the week number corresponding to the start of the next monitoring period and must be greater than or equal to the value for the monitoring frequency for the prior period.
- Now, specify what happens in the next monitoring period. Enter a value for the Monitor every field and choose until LSLV or until week.
- Repeat as necessary to define each change in frequency over the
                  course of the monitoring schedule.
                                       ClearTrial calculates the total number of visits to be made, derived from the remote monitoring frequency and the subject enrollment rate, and displays it in the Total Remote Visits field.
- If you know the total on-site visits and you can’t achieve it by adjusting the frequency of visits per interval, you can override the system-calculated value. The overridden value will be used downstream instead of the ClearTrial default or the user-defined on-site monitoring schedule values.
                LSLV.
- Override the total number of monitoring visits in the Total
            on-site visits field, if necessary (for example, if the value in the RFP is
          different from the generated value).
                           - ClearTrial derives the default value shown from the total number of sites, monitoring frequency, and subject enrollment rate, treatment, and follow-up periods (FSFV to LSLV). You can increase this number to add more monitoring visits. You can also lower the total number of monitoring visits.
- If you are working with new sites that have limited research experience or where you know that there is a need to accelerate monitoring for some reason, add monitoring visits. For example, if ClearTrial calculates 1068 visits and there are 89 sites in the study of which 35 are inexperienced, you might add one additional monitoring visit for these 35 sites. The new number of monitoring visits is 1103.
- Oracle recommends that the total number of visits entered be as close to the value calculated by ClearTrial as possible. That is, try to adjust the monitoring frequencies to arrive at the desired value and, only if you cannot achieve the desired number, enter a new value to override the calculated value.
- From the Monitoring
            Travel Strategy drop-down list, specify the monitoring visit strategy to use
          for most of the monitoring trips.
                           - Spoke monitoring— The monitors return to their homes or offices between each visit.
- Loop monitoring— Monitors travel to site 1, then to site 2, then
              to site 3, and so on, before returning to their homes or offices.
                                 For studies that have slower enrollment, with slower data being generated and slower distribution, such as Oncology studies, Oracle recommends using the Spoke travel strategy because there will be less frequent visits but of longer duration. For studies with shorter enrollment periods and more even distribution and generation of CRF data across sites, use the Loop visit strategy to leverage more frequent visits of shorter durations. A local CRA can monitor multiple sites in one trip before returning home. ClearTrial defaults to Loop visits because they are more cost efficient.
- Use the Monitoring Schedule chart or the Monitoring sections of the Assumptions report to verify the schedule.
- Note that ClearTrial always assumes Spoke travel for closeout visits.
- Set up the monitoring approach or click Next to open the Provider tab.
When you select Centralized monitoring, corresponding labor activities are included by default in the budget.- In the Remote Monitoring Schedule section of the Monitoring tab, in the Monitor every field, specify how frequently a monitor will contact the sites during each period of the monitoring schedule.
- If the remote monitoring will continue at the specified frequency throughout the
          study enrollment, treatment and follow-up periods (FSFV to LSLV), select until
            LSLV.
                           - If the monitoring frequency will change during the treatment or follow-up period, the select the until week radio button and define a new frequency for the next (or remaining) period.
- If there are no treatment arms with a follow-up treatment defined, then LSLV = LSLT. When there is a follow-up period defined for one or more treatment arms, thenLSLV = LSLFU(Last Subject Last Follow Up visit or data collection event).
- If you want to use a variable monitoring frequency; for example, contacting every
                                                  four weeks in the beginning of the study, every
                                                  six weeks at the end of the study:
                           - In the Monitor every field, select until week and enter the week at which this frequency ends and a new monitoring frequency begins.
                                                  each change in frequency over the course of the
                                 ClearTrial calculates the total number of contacts to be made, derived from the remote monitoring frequency and the subject enrollment rate, and displays it in the Total Remote Visits field.
- If you know the total remote visits and you can’t achieve it by adjusting the frequency of visits per interval, you can override the system-calculated value. The overridden value will be used downstream and instead of the ClearTrial default or the user-defined remote monitoring schedule values.
- In the Average hours per remote visit field, specify the average number of hours required to perform a remote monitoring visit, including preparation and follow-up activities.
If you also chose Remote from the Monitoring Methods section of the Monitoring tab, the default schedule uses a frequency-based model to calculate the total number of remote visits.- In the Remote Monitoring Schedule section of the Monitoring tab, in the Monitor every field, specify how frequently a monitor will contact the sites during each period of the monitoring schedule.
            LSLV.
- In the Average hours per Remote Visit field, specify the average number of hours required to perform a remote monitoring visit, including preparation and follow-up activities.
These monitoring assumptions are only available in Advanced or Expert Edit Mode.Parent topic: Review and Adjust Monitored Data on the Monitoring Tab
These monitoring assumptions are only available in Advanced or Expert Edit Mode.- On the Monitoring tab, in the Medical Monitoring section, select the 24/7 coverage radio button to require 24/7 coverage by the medical monitor for the study. This means the medical monitor is on call to address any site- or subject-related questions including, but not limited to, subject inclusion/exclusion criteria in accordance with the protocol, protocol violations or deviations that may occur during the study, or any other general medical monitor-related questions.
- In the Number of medical data listing reviews field, enter the number of reviews required for the particular study being planned.
- Enter drug accountability options in the Separate Drug Accountability section or click Next to enter assumptions on the Provider tab.
