Changing Tasks
There are two methods you can use to change from one data entry task to another:
  1. Exit from the current data entry task, and select the other option from the Data Entry menu.
  2. While in the Received DCI or Received DCM window, click Change Task and choose the alternative mode from the task-selection pop-up window
    This choice preserves some of the key context; for instance, if you switch from Initial Log-In to Browse mode and return to Initial Log-In, the record you were working on when last in that task is re-displayed. Also any query criteria you enter in one mode are preserved in the new mode.
When changing modes using the Change Task function, your access privilege is controlled by the same permissions as for the equivalent main menu activity.
