Create View Accounts
To implement view selectivity—that is, to submit only those views you want—mark study (set) access accounts as Create or Drop in either the Maintain Study Access Accounts or the Maintain Study Set Access Accounts window. Open these windows by selecting Data Extract from the Conduct menu. These windows enable you to view existing study access accounts. You can also create Snapshot accounts.
When the fields in the Maintain Study Access Accounts window are completed the way you want them, you can submit the access account to the PSUB form, Maintain Data Extract Views, to obtain views. You need only create access accounts once; you do not need to create them at all if you are satisfied with the default views.
The Maintain Study Set Access Accounts window has the same fields as the Maintain Study Access Accounts form. The available studies however, are sets of studies.
At least two of the studies in a cross-study view must belong to a study set for an account to be created.
Parent topic: Workflow
