Entering Manual Discrepancies
If there is a general problem with a visit record, you can enter a manual header discrepancy. This type of discrepancy is not directly associated with a single response, but to a Received DCM's data in general. You can enter manual header discrepancies only from the Maintain Discrepancy Database window. If you are unable to enter a particular response because, for example, the entry is illegible in the Case Report Form, you can create a manual data point discrepancy, either from the Data Entry window or directly in the Maintain Discrepancy Database window.
To create a manual discrepancy from the Maintain Discrepancy Database window:
Parent topic: Managing Discrepancies
