Example 2: Oracle Format with Substitution Parameters
DEFINE S_Study_ID = 100
DEFINE DCM_1 = 003
DEFINE DCM_2 = 004
DEFINE DCMQ_1 = 123
DEFINE DCMQ_2 = 456
DEFINE DCMQ_3 = 789
select /* + ORDERED USE_MERGE (cpe)
INDEX (r RESPONSE_UK_IDX)
INDEX (cpe CLIN_PLAN_EVE_UK2_IDX) */
substr(rdcm.document_number, 1 0) ||'WK14338' study,
rdcm.patient pt,
rdcm.clin_plan_eve_name cpevent,
r.repeat_sn repeatsn,
max(decode(r.dcm_question_id, &DCMQ_1, substr(r.value_text,1,8),
&DCMQ_2, substr(r.value_text,1,8), &DCMQ_3, substr(r.value_text,1,8)))
var1
from clinical_planned_events cpe,
rdcms_view rdcm,
responses_view r
where rdcm.clinical_study_id = &S_study_ID and
rdcm.dcm_id in (&DCM_1, &DCM_2) and
r.dcm_question_id in (&DCMQ_1, &DCMQ_2, &DCMQ_3) and
r.received_dcm_id = rdcm.received_dcm_id
group by substr(rdcm.document_number, 1 0) ||'WK14338' study,
rdcm.patient,
rdcm.clin_plan_eve_name,
r.repeat_sn
Parent topic: File Format for Externally Loaded Views
