Indicators of an Existing Discrepancy
Several display characteristics indicate that a discrepancy exists for a field. These indicators display in all entry modes except those where the operator is explicitly blinded to the presence of univariate validation failures.
blue—indicates an existing discrepancy
red—indicates multiple discrepancies, or a discrepancy plus an Investigator comment
(<Univ.>) displayed in the title bar of the data entry window—univariate discrepancy lamp, indicating a discrepancy
You can display a pop-up window with discrepancy information by invoking the Display Univariate Discrepancy function. If the Resolve Discrepancies during Data Entry configuration parameter is enabled, you can also modify the review status, comment, and mark the discrepancy as resolved.
Parent topic: Validating Data Entry
