Running the Group Update on the CDS
When you finish specifying the group update, click the Do Grp Update button in the Group Updates dialog box. The system makes the changes to the CDS only, and makes a record of the group change.
The changes you enter will be applied to all the records in the CDS unless:
  • They have a status of IG (because they were manually excluded; see Excluding Records from the Group Update) or AS (because changes have already been applied to the database for the record through this CDS).
  • You can write a Where clause in the appropriate field in this window to identify a smaller group of records to which to apply the change.
