Soft-Deleting RDCIs
An RDCI corresponds to a CRF, or Oracle Clinical "document". The only change you can make to an RDCI through the RDCI Soft Deletes Mass Change utility is to delete the entire CRF.
You might want to do this, for example, if an operator logged in many RDCIs under the wrong study. You cannot use Mass Changes to correct these errors; the RDCIs need to be properly re-entered.
The system maintains a record of the existence of the RDCI for audit purposes; it is not deleted entirely (hard-deleted).
To soft-delete RDCIs, do the following:
Parent topic: Making Mass Changes: Group Updating
