STANDARD Mask Format
The STANDARD mask is the format used by default when a new data file is created.
The following table lists the expected order of column values for each record, with the first ten characters (1-10) allotted to the first column value, the second ten characters (11-20) allotted to the second column value, and so on. Certain columns are mandatory.
Table 7-1 Default Batch Data Load Fields
| Name | Position/Type | Description | Mandatory? |
| Investigator | 01:10 CHAR | Investigator | No |
| Site | 11:20 CHAR | Site | No |
| patient | 21:30 CHAR | Patient | Yes |
| document_number | 31:50 CHAR | Document Number: Leave document _number blank if your location uses document number derivation (see "User-Defined Identifier Handling" in the Oracle Clinical Application Programming Interface Guide). Otherwise, leaving it blank causes errors loading multiple DCMs/DCIs at once. If given, document number is used even with the document number derivation defined. | No |
| clin_plan_event_name | 51:70 CHAR | Clinical Planned Event | Yes |
| subevent_number | 71:72 NUM |
Subevent Number *This column is mandatory if there is no value for dci_date. |
No* |
| dci_date | 73:80 CHAR |
Visit Date (YYYYMMDD): dci_date = dcm_date, and dci_time = dcm_time; if dci_time= null, both dci_time and dcm_time = null. Note: Do not enter zero to represent an unknown part of the date (for example, 20110000). Instead, leave the date partial (for example, 2011). *This column is mandatory if there is no value for subevent_number. |
No* |
| dci_time | 81:86 CHAR | Time of Visit (HHMMSS) | No |
| dci_name | 87:116 CHAR | DCI Name | Yes |
| dcm_name | 117:132 CHAR | DCM Name | Yes |
| dcm_subset_name | 133:140 CHAR | DCM Subset Name | Yes |
| dcm_question_grp_name | 141:170 CHAR | Question Group Name | No |
| dcm_question_name | 171:190 CHAR |
Question Name Note: Before adding a question, make sure that it is not derived. You can check by navigating to Glib, Questions, and then Questions and querying for the question. |
Yes |
| dcm_que_occ_sn | 191:193 NUM |
Question Occurrence Sequence Number (0 if none) |
Yes |
| repeat_sn | 194:196 NUM |
Repeat Sequence Number (1 if no repeats) |
Yes |
| value_text | 197:396 CHAR | Value Text for the question. If the question has a default value, repeating or non-repeating, provide user data here if it is not provided. | No |
| data_comment_text | 397:596 CHAR | Data Comment Text | No |
| qualifying_value | 597:666 CHAR | Qualifying Question Value Text, if applicable. Qualifying value is mandatory if required by DCM definition; it is ignored otherwise. | No |
| Study | 667:681 CHAR | Study | No |
Parent topic: Defining and Using Format Masks
