Temporary Changes
You can use the profile setting as a temporary query filter without permanently applying your changes to the profile; modify the criteria, then click the Use button, leaving the Save My Changes box blank. To change the criteria later in the session, click the Change Profile button in the Maintain Discrepancy Database window to reopen the Profiles dialog box.
Parent topic: Changing a Profile
