Using Oracle Clinical-Siebel Clinical Integration
If you are using both Oracle Clinical and Siebel Clinical for a clinical study, you can integrate the two systems to automatically pass certain data and metadata from one system to the other in order to:
  • Signal the completion of visits and activities.
  • Simplify study setup in Oracle Clinical and Subject setup in Siebel Clinical.
You can also integrate Oracle Clinical with other clinical trial management systems. For further information, see Integrating with a Clinical Trial Management System
