Gather Required Information
Have the following information ready.
Install the Oracle WebLogic Server
- Home directory path; for example:
C:\Oracle\Middleware\Oracle_Home - Email address to receive security updates specific to your installation
- My Oracle Support password if you wish to receive the security updates through My Oracle Support
Install the Oracle Fusion Middleware Infrastructure Software
Install the Oracle Forms and Reports Servers
Create the Repository Creation Utility
- Database details:
- Server.Domain; for example:
servername.your_company.com
- Port number
- Database service name
- Database administrator username and password
- RCU Schema password
Configure the FRDomain
- Domain home path; for example:
C:\Oracle\Middleware\Oracle_Home\user_projects\domains\FRDomain - Application location; for example:
C:\Oracle\Middleware\Oracle_Home\user_projects\applications\FRDomain - WebLogic Domain administration username and password
- RCU Database connection:
- DBMS/ Service name
- Port number
- Schema owner name and password
- Node Manager credentials: Username and password
Oracle HTTP Server details:
- Administrator host’s IP address
- Administrator port number
- Listen address
- Listen port number
- SSL listen port number
- Server name
Parent topic: Install and Configure the Oracle Application Tier
